Feedback sur Brushless RedFlag RC?
Cactuszebest
Message par Cactuszebest »
je suis a la recherche d'avis sur les ensembles BL Crawler de chez Redflag RC.
Est ce que quelqu'un en a déjà eu un?
les données:
eZRun 25A brushless ESC, Waterproof and dustproof
540 size, High torque brushless motor
fit 1/10 crawler, see my other list for 1/8 heavy duty crawler
Key Features & Specs:
Brushless ESC (speed control):
Features:
eZRun 25A fully Programmable brushless ESC with Cooling Fan
Specially designed for RC Car & Truck, Waterproof and dustproof.
Excellent start-up, acceleration and linearity features.
Top quality electronic components to enhance the current endurance ability of the ESC.
2 running modes (Racing mode and Forward/Backward mode)
Low voltage cut-off protection, Over-heat protection
Throttle signal loss protection, Motor blocked protection.
4 steps of maximum reverse force adjustment.
Proportional ABS brake function with 4 steps of maximum brake force adjustment,
8 steps drag-brake force adjustment, 4 steps of initial brake force adjustment.
4 start modes from soft to very aggressive.
8 steps of timing adjustment.
Easy to program with SET button (build in ESC) or with program card (optional parts, purchase separately)
Specs:
Output: Continuous current 25A, burst current 90A
Input: 4-9 cells NiMh/NiCd or 2-3 cells LiPo
BEC Output: 6V/1.5A
Resistance: 0.005 Ohm.
Motor Supported: Sensorless Brushless Motor
Dimensions: 31.5mm(L) * 27.5mm(W) * 24mm(H).
Weight:30g (Without wires)
Brushless motor Specs:
Construction: Sensorless, Outrunner, 12 magnetic pole
540 motor size, Precision Ball Bearings
890KV, recommend work with 25-35A brushless ESC
Work with 6-14 cell NI-MH or 2-5 cell Li-Po pack
Diameter: 35.8 mm
Length: 50 mm
Weight: 170g
Shaft diameter: 3.175 mm (1/8")
Shaft Length: 16 mm
Package included:
1 890 KV brushless motor with 3 pair 3.5mm bullet connecters
1 Hobbywing eZRun 25A brushless ESC
User Manual
Nikos
Re: Feedback sur Brushless RedFlag RC?
Message par Nikos »
Hi,
J'ai vu cet ensemble aussi !!! en apparence ça a l'air sympa, maintenant, je ne sais pas si quelqu'un l'utilise déjà... :|
Si quelqu'un a testé, dites nous !
Merci ;)
Cactuszebest
re,
donc, j'ai testé pour vous.
J'ai acheté un moteur BL 890kv et pour le controleur, j'ai pris le 35A à la place du 25A.
J'ai aussi la carte de programmation, mais je ne l'ai pas encore testé celle ci.
J'ai monté cet ensemble sur mon Axial AX-10.
Au final, je peux dire qu'il y a beaucoup de couple, par contre la vitesse de pointe est digne de celle d'un escargot au galop.
C'est d'ailleur tellement lent qu'on ne sent pas trop la progressivité du controlleur.
Il y a un ventilateur branché sur le controleur qui le refroidit en permance.
En tous cas pour 75euros fdpin, c'est un bon investissement. Je pense serieusement à en prendre d'autre.
Attention par contre au montage. Le moteur est à cage tournante donc il doit y avoir un peut de place autour de celui ci.
olivier30900
Message par olivier30900 »
Pour info, eZRun = Feigao ;)
