[REFERENCE] Tamiya FF03
nitrous
Message par nitrous »
Salut!
pour éviter de polluer le Topic des nouveautés Tamiya, je propose de mettre toutes les infos relatif au FF03 ici. ça nous permettra de mieu le connaitre en attendant qu'il arrivent chez nous :)
vidéo du FF03 lors du Salon de Shizuoka 2010
[youtube]<object width="640" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>[/youtube]
voici quelque photos croisé sur le net:
Tamiya is proud to announce the release of the FF-03 PRO, the newest touring car chassis kit in their line-up. The FF-03 chassis features a horizontally-placed front-motor, front wheel drive and comes enhanced with a range of high performance parts to offer you a new driving experience. Due to its unique chassis layout and FWD setup, you can enjoy a style of driving different from 4WD chassis machines. The chassis features a newly designed lower deck and comes with a compact front gearbox. Suspension is equipped with short reversible suspension arms and TRF416 uprights on the Inboard Front Suspension (IFS) setup. True to its name “PRO”, high-spec parts such as TRF dampers, aluminium turnbuckle shafts, and aluminium ball connectors are also included in the kit.
About the Model
* This is a 1:10 R/C assembly model kit.
* Chassis length: 384mm, Overall width: 185mm, Tread: 157mm, Wheelbase: 257, 245, 233mm.
* FWD chassis features front-mounted motor and is designed for optimum weight distribution and a low centre of gravity.
* Body, tyres, ESC, motor, R/C unit, battery and charger not included.
* Front suspension features the IFS setup.
* The damper mount is equipped with stabilizer holders.
* 3 wheelbases (257, 245, 233mm) can be assembled by replacing rear block parts.
* Rear dampers can be installed to either side of the suspension arms.
* Slim chassis features longitudinal battery position.
* R/C unit is placed on each side for optimised chassis balance.
* Motor is securely attached to blue-anodized aluminium motor plate which enhances dissipation of motor heat.
* The compact gearbox is equipped with a large-sized ball differential.
FF-03 PRO Chassis Kit includes the following Option Parts:
* Item 42102 TRF Special Damper (Hard Black Coating) plus Titanium Coated Piston Rods and White Coil Springs (Medium x2, Hard x2)
* Item 51000 Hi-Torque Servo Saver (Black)
* Item 53159 4mm Anodized Aluminium Flange Lock Nuts (Blue)
* Item 53642 5mm Aluminium Ball Connector (Blue)
* Item 54121 Aluminium Horn For Hi-Torque Servo Saver
* Item 54223 FF-03 Aluminum Motor Plate (Blue)
* Aluminium Turnbuckle Shafts (Blue)
* 5mm Adjuster (Grey)
The following Spare, Option, and Limited Edition parts for FF-03 Chassis machines will also be released in conjunction:
* 51419 FF-03 B Parts (Bumper)
* 51422 FF-03 M Parts (Damper Stay)
* 51423 FF-03 06 Spur Gear (68T)
* 54223 FF03 Aluminium Motor Plate (Blue) (Tentative)
* 54226 3/32 Inch Tu Ball (12pcs.)(Tentative)
* 54227 FF-03 04 Module Spur Gear (102T)
* 54228 Fluorine Coated 06 Module Pinion Gear (26T, 27T)
* 54229 Fluorine Coated 06 Module Pinion Gear (28T, 29T)
* 54230 FF-03 Stabilizer Set (Front & Rear)
* 54233 FF-03 Aluminium Diff Joint Set
* 54234 FF-03 Aluminium Spur Gear Mount
* 84130 FF-03 Ti Screw Set
FF-03 chassis machines are compatible with many 1:10 R/C touring car Spare Body Sets, but they are NOT compatible with the following:
* Item 50809 Peugeot 306 Maxi WRC Body Parts Set
* Item 51223 Audi A4 DTM 2005 Lightweight Body Parts Set (Finished)
* Item 51265 ADVAN Courage LC70 Mugen Body Parts Set (Finished)
* Item 51288 BMW 320si WTCC 2006 Team Germany Body Parts Set
* Item 51292 EBBRO 350R Body Parts Set
* Item 51295 BMW Z4 M Coupe Racing Body Parts Set
* Item 51306 Raybrig NSX 2007 Body Parts Set
* Item 51322 Nissan Fairlady Z Version NISMO Body Parts Set
* Item 51357 ARTA Garaiya Body Parts Set
* Item 51359 Xanavi NISMO GT-R (R35) Body Parts Set
* Item 51395 Corolla Axio apr GT Body Parts Set
* Item 51396 BMW M3 GT2 2009 Body Parts Set
* Item 51401 Lancia Delta Integrale Body Parts Set
58463 1:10 R/C FF-03 PRO Chassis Kit
Availability: May
Source: Tamiya
Version normal:
Version Pro:
et une Pro presque toutes option:
quelques autre photos:
info trouvé sur divers forum Français et Américain.
Dernière modification par nitrous le 17 mai 2010, 20:08, modifié 2 fois.
Re: Topic du Tamiya FF03
très bonne idée, mais est-ce que ce ne serait pas mieux de le mettre en on-road 2WD ? voire même carrément comme topic de référence ?
hagard_dusud
Message par hagard_dusud »
Hummm, superbe... :love:
Pour les options, il y a tout de même deux trois petites choses qui me chiffonnent.
-> A quoi peuvent bien servir les barres alu bizarroïdes autour du moteur ? Elle ne remplacent aucune pièce du kit (même pro) et ne semblent pas avoir une évidente légitimité structurelle ?
-> Les barres anti roulis... Avce la longueur des renvois verticaux... vous y croyez beaucoup vous ? Moi, non, et c'est dommage, parce que le jaune rends super bien.
-> La barrette d'accu en carbone, ben, tant qu'il n'y a pas de châssis carbone au programme, je trouve ça bof...
Voilà pour mon sentiment en découvrant ces photos... et pour les carrosseries, ça va faire plaisir à tous ceux, dont moi, qui attendait une carrosserie correcte pour remonter leur FF01 Il va y avoir de la 156 dans l'air.
Comme BHS, si Nitrous se sent de mettre régulièrement son post principal à jour, voilà un topic qui a sa place en référence.
marcolino
Message par marcolino »
Les barres alu bizarroïdes dont tu parles ce sont les radiateurs moteurs, comme sur le DF03 ou le MO5.
nitrous
merci :oops:
je ferais le nécessaire pour que le post soit mis a jour régulièrement! en meme temps, je vais m'en prendre une des la sortie avec surement quelques options, en attendant de me prendre un Serpent S811 Cobra :ange:
je pense qu'un chassis carbone devrais voir le jour chez Tamiya, sinon, pourquoi faire une simple barrette d'accus? au pire, des "optioneurs" en feront un peut de temps après la sortit du kit.
pour les barre bleu, je pense que ça doit jouer un peu sur la dissipation de chaleur du moteur, vu qu'elles sont monté sur le supports moteur.
les BAR avec renvoie, je pense que ça marche!
hagard_dusud
marcolino a écrit : Les barres alu bizarroïdes dont tu parles ce sont les radiateurs moteurs, comme sur le DF03 ou le MO5.
Ah... bien, merci,
Je ne connaissais pas cette options, tout comme les deux châssis qui en bénéficient.
Et les retours d'expérience sont bon sur ces dissipateurs ?
marcolino
Oui ça fait son office, après c'est plus ou moins utile selon le type de chassis. Par exemple sur le DF03 où le moteur est complètement renfermé c'est plus utile que sur ce FF03 où il a l'air assez aéré.
Bon après il y a aussi le côté look :)
nitrous
je vien de trouver un mag au japon qui me préviendra par mail des que les pré-commande ou même les commande seront enfin possible :smoke:
http://www.1999.co.jp/eng/10114384
le-fou-du-vintage!!
Autant les châssis piste Tamiya mon écœure avec la TT01... Autant lui je me laisserais bien tenter en version XB pour avoir un belle carro bien peinte car moi je sent que je vais encore tout foirer et comme ce sont de magnifique carro ça me ferais mal au cœur
Jsm
Message par Jsm »
En voila une idée qu'elle est bonne !!! un topic spécial FF03 :hehe:
je vais craquer quand il va sortit le petit !!! :o
la carro de civic castrol :love:
une idée des tarifs de ce bébé ou du moins une approximation ?
allez un topic de plus a suivre :hehe:
