Je suis paumé, ce variateur est il compatible moteur à charbons ? D'autre part, j'emploi une radio avec recepteur 41 mhz, est ce compatible ?
merci :salut:
LRP A.I reverse
- Shionn
Re: LRP A.I reverse
Il y a eu plusieurs lrp ai reverse. Tu as une réf précise?
http://www.shionn.org
matth1976
Re: LRP A.I reverse
C'est celui-ci
LRP (#83020) A.I. Runner Reverse ESC Ver.2 - RC Car Electronic Speed Controller
Feature:
•No button - no setup = no problem
•LRP exclusive!
•Works with synthesizer-, crystal- and 2.4GHz receivers
•A.I. = Artificial Intelligence
•No manual user setup required at all!
•Just plug in, switch on and drive
•The built in Fail Safe System is a technological highlight. “The guardian angel†of your RC car. The Fail Safe System continuously monitors the radio signals being sent to your RC car. If incomplete or “false†signals are received as a result of low batteries or radio frequency interference, your LRP A.I. Runner Reverse Version 2 speed control reacts instantly and shuts off your model to protect it against damage due to interference.
•Digital interference protection circuitry
•“THE PROTECTION“ against interference, empty transmitter battery or model outside the radio range
•The model stops instead of continuing uncontrolled
•No more damaged models due to interference
Specification:
•Set-up Procedure: automatic
•Fail Safe System: yes
•Voltage input: 4.8 - 7.4V
•Type: Forward / Reverse
•Typical Voltage Drop @20A: 0.152V
•Waterproof: yes
•B.E.C.: 5.0V / 1.0A
•Dimensions: 26.0 x 26.0 x 15.7mm
•Rated Current (at 7.2V): 92A
•Rec. Motorlimit (at 7.2V): over 16 turns
Include:
•LRP A.I. Runner Reverse ESC Ver.2 (1pc)
Feature:
•LRP exclusive!
Specification:
•Waterproof: yes
Include:
- pottok
Re: LRP A.I reverse
C'est bien un vario pour moteur brushed (Ã charbons) qui peut accepter les moteurs jusque 16trs pas moins.
Aucun problème de compatibilité avec un récepteur 41mhz
C'est pour mettre sur laquelle de tes RC ?
ヨコモを再リリースしないでください
ヨコモを再リリースしないでください
matth1976
Re: LRP A.I reverse
Ca serait pour mettre sur le DF 02 lorsque je changerais le dirt tuned
- Tamiya4ever
Re: LRP A.I reverse
Nickel :top: et en plus il a un fail-safe intégré, c'est bon ça.
ma tite collec
ma tite collec
tom818
Re: LRP A.I reverse
C'est le variateur idéal, de marque LRP, pour moi c'est le top.
Tu va te faire plaisir.
matth1976
Re: LRP A.I reverse
B au final j'ai opté pour un HPi SC15
Là ou j'avais dégotté le moteur Stck BZ le gars en vendait aussi. Alors histoire d'éviter les multiplications de colis
Merci de vos réponses :salut:
