Nouveau Kyosho Blizzard RTR
Happy78
Gentil membre
Message par Happy78 »
Nouvelle édition du Kyosho Blizzard avec telecommande 2,4 Ghz et pelle fonctionnelle
http://www.kyosho.fr/index.php?option=c ... le&id=2…
This is the Kyosho Blizzard SR "Search & Rescue" 1/12 Scale ReadySet All Terrain Belt Vehicle. The one of a kind Kyosho Blizzard has been revamped and now available in a ReadySet package! With dual 380 size high torque motors, the blizzard can climb, push, and power over just about anything. This simple and efficient setup allows more realistic and complex movements. Spin turns on the spot are easy to perform, while the dust and snow proof chassis design enables the vehicle to run reliably almost anywhere. Many game type activities such as mini soccer and crawling type races can be developed, providing you with a truly fun vehicle for all hobby enthusiasts that can tackle all types of terrain.
Expansion: Includes 3rd channel function for front shovel/snow plow movement. The 4th channel on the radio is open for future expansions. Various option parts such as rear roller unit, light set, high grade belt set, and high torque shovel servo will be available in the future.
Body: Scale looking body comes assembled, with an extra decal set allowing personal customization.
What is a Ready Set? A ReadySet is a fully assembled model that includes nearly everything you need to run. The body is complete so only consumables like batteries (7.4v LiPo, or 7.2v NiMH), charger and transmitter batteries are required so you can start operating the model without delay.
Features:
  • Newly developed high spec ESC units
  • Dust and snow proof chassis design with inner covers covering all critical areas (gears, motors and ESC's).
  • Reliable KS101BK servo for shovel controls
  • Two 380 size motors for easy controls and high torque output.
  • Velcro belt secured battery tray compatible with most stick pack batteries (7.4V Li-Po compatible).
  • Realistic light weight traction belts
Specifications:
Scale: 1/12
Length: 560mm
Width: 260mm
Height: 187mm
Wheelbase: 316mm
Tread: 215mm
Weight: 2600g (w/Body)
Gear Ratio: 8.86:1
Tire Diameter: 93x38mm
Transmitter:
KT-200
Includes:
  • Fully factory assembled chassis
  • Pre-painted body
  • KT-21 2.4GHz Transmitter
  • Hex Wrench
  • Cross Wrench
Needed to Complete:
  • (8) AA Batteries for TX
  • 7.2 - 7.4V Battery Pack & compatible charger
LeGlod
Re: Nouveau Kyosho Blizzard RTR
Message par LeGlod »
Des 380 :| ca va couter cher ce truc, on pourra enlever la neige devant la porte avec ou pas ?? :hehe:
Salut bonne nouvelle sa. Surtout pour la pelle avant. L utilisation de de deux moteurs est un bon choix, et si les moteurs dorigine sont un peu poussif, on pourra y remplacer par deux petit combo brushlesspas. Cher vu la taille des moulin. Kyosho se demene en ce moment, il sorte aussi un offshore F1 de toute beaute, encore faut il que cela arrive chez nous et a un prix correcte. A+
Voilou la bete http://www.kyosho.com/eng/products/rc/d ... _id=107674
Happy78
Gentil membre
Joli ce F1.
Il doit être dipo :top:
Concernant le tarif du Blizzard :
http://www.amainhobbies.com/product_inf ... le-w-24GHz
Ps: l'ourson, je part surement sur un Moon :ange:
Toresh
Message par Toresh »
Sympa la pelle fonctionelle.
Par contre, je trouve que cela reste assez cher :s . Du moins chez nous...
Toresh
Flunk
Message par Flunk »
Arf le formula boat... :love:
C'est exactement le genre de modèle que j'attendais pour taper
la bourre sur l'étang municipal !
J'ai cherché mais je ne le trouve malheureusement pas ,
c'est pourtant marqué comme disponible en août 2011... :|
LeGlod
Happy78 a écrit :Joli ce F1.
Heuuu ya moins cher meme si pas en stock http://www.speed-rc.com/Blizzard-EP-SR- ... -1.html#fp :|
